ABS Module rebuild - recommendations?
    Originally posted by davidlo19a View Post
    Hello all.
    Recently chasing down an error with the ASC/DSC module in my 2001 E46 M3, I opened the cover to find leaky capacitors, destroying part of the circuit board.
    Do you happen to have a high resolution picture around the capacitor area? I'm trying to rebuild the traces.
    Thanks a lot!!
    This is mine currently.
    Sorry, that's the best picture I have. Does that corrosion clean up with isopropyl alcohol or is that a lifted pad on the bottom?
    If it is lifted, you could try tracing the PCB with a multimeter and running a jumper wire from the new cap to the next clean spot in the trace. Looks like it might just be ground for that one.
      Unfortunately multiple traces are affected, some even went into layer 2. I’m trying to rebuild the traces but no success. Would you still happen to have the one opened up that you don’t need anymore?
        I don't, sorry.
        I scavenged that one for parts to build an MK20 -> MK60 adapter harness.
          A pro electronics repair place might be able to do it.
          Maybe it's worth going to a Mk.60
