Lightweight battery
No experience with either model you listed. We have a small lithium battery on the track car. It has sn undervolt switch to avoid leaving you stranded. Its on the battery itself. For a street car I would recommend a remote switch to the drivers cockpit area so you're not digging in the trunk to start the car.
I've been running a Brail GU1R for over 4 years now, and not had as single issue. That said, I do put it on a maintainer if I'm parking the car for more than a week or two. That said, I also do that on the stock battery M5 and M3 wagon, soo....
When it ages/cycles out, I intend to replace it with something with an automatic cutoff feature, as that does seem like nice peace of mind. But, doesn't seem like it's worth replacing a wear item preemptively for that functionality.
Thank you everyone for the advice. I’m looking to cut the most weight from the car and I like features that allow me to see voltage of the car so I might go with the anti gravity but the lite blox has some features that I like. My car does not have raiding or other features that consume a lot of power so I’m not worried about a lithium battery. My battery is about four years old and I believe I’ll need to replace it soon.
Ive had the Braille GU1r for 4.5 years now with no issues. It is 4.5# i believe. I also have a small 4 channel stereo amp that it powers, and the car sits for long periods sometimes. In the longer periods, I use their trickle charger to keep it fresh.2003 Carbon Black - Karbonious CSL intake, CSL DME w/MAP, SSV1 headers/Catted Section1/63.5mm Section2, Shrick 280/272 cams, Lang Racing Stage 1 cylinder head, Eibach Pro Street S Coilovers (500#F/600#R), GC Sways, AutoSolutions SSK, Motorsport 3.91 rear diff, BBS RGR wheels, Streamline CSL front bumper
This has been 5 years now, curious what battery you are running now? I need to replace my battery eventually, its from 2018 hahaha so I want to get something good and light. I will have it on a tender for the most part since its always garage kept in a climate controlled environment and will be out on track days or cruising.Originally posted by Obioban View PostI've been running a Brail GU1R for over 4 years now, and not had as single issue. That said, I do put it on a maintainer if I'm parking the car for more than a week or two. That said, I also do that on the stock battery M5 and M3 wagon, soo....
Still have radio and speakers but thats it.
Still running the same Braille GU1R-- over a decade old now! Still has never given me a single issue.Originally posted by Tonggi View Post
Not bad for <6 lbs.
They no longer sell it for some reason. You have full radio?Originally posted by Obioban View Post
Still running the same Braille GU1R-- over a decade old now! Still have never given me a single issue.
Not bad for <6 lbs.
Im going to try and find an exact replacement that Braille has now and I will get the same thing knowing you got no issues. A DECADE!!!
I do not have a full radio. Xtrons head unit (for factory looking wireless carplay) and front door speakers, and that's it. Took ~45 lbs of stereo modules/wiring/brackets/speakers out of my car!Originally posted by Tonggi View Post
ok my rear speakers are on their way out. All i have is a EONON, I wil k eep front doors (maybe, the damn door handle is in my way when turning will see if a smaller diameter wheel will fix that since my arms are short) and I will remove the rear deck lid or sub. No CD player etcOriginally posted by Obioban View Post
Also do you recall, this is off topic if I need to rewire door airbag if I remove doors?
And I am guessing you have LIPO battery tender?
Not sure what you're asking on the rewiring of door airbags.Originally posted by Tonggi View Post
I do have a CTEK LiPo tender. But, I only use if if I'm not going to be driving the car for 2+ weeks or so, which pretty much just means over winters.
Ignore door airbags Ill research that myself. But sounds good on battery. I will get the new equivalent. Which is a Braille Performance GreenLite Lithium-ION Battery - G30 going for $530, Is that roughly what you paid for your battery back then?Originally posted by Obioban View Post
