288/280 vs 280/272 cams.
  • EzM3
    Hey all, I'm kinda new to the cam world (it's teased me ever since I saw the group buy on the old forum)... I daily my car, so I'd like to go with 280/272- do I need to just buy cams and throw them in? Or are there any other parts I need to buy with 280/272s? I suppose tune as well.
    Thanks guys. Some awesome information and knowledgeable guys on this thread.
  • duracellttu
    Originally posted by M3KVU View Post
    What power did you get in the end mate ?
    Just created a separate thread with my build details and results. See below...
    https://nam3forum.com/forums/forum/m...w-dyno-results
  • duracellttu
    Interestingly enough on one of the other forums I was on a guy who had a genuine CSL said occasionally he found little blips with it but never with the stock maf version when he had the regular m3
    Oh wow, that's new information. Maybe this isn't a much of an issue as it seems.
  • digger
  • NZ_M3
    I was under the impression that the "CSL hesitation" was something that only happened to MAP-less alpha-n setups? Or maybe I'm conflating two different problems. Is this something that happens on real CSLs?
    I have done so many CSL airbox conversions here in NZ for others and I have never ever had a case of the so called hesitation.
    I even made a video for someone in the States privately of my CSL trying to replicate the so called hesitation at various gears from 3000rpm and have not been able to replicate it at all.
    i have however managed to replicate it via an Alpha N tune I received from the UK so I do know what it is and what it feels like.
    A correctly converted car with a healthy engine just doesn’t have this issue. Period.
    I have had my converted M3 with the csl airbox also for just over 3 years now and it has 189k km and I have not been able to replicate this issue either with it.
  • D-O
    Originally posted by HassanEido View Post
    I have not, but I've done enough cars to piece a clear enough picture of what to expect with each setup.With that said, cams aren't a magic bullet. The has to be in top shape otherwise obviously, I've seen stock cam cars make more than some cammed cars, and some cammed cars making 50 whp more( with similar state of tune barring cams)..so ymmv. But in general, the trend in power gain is as described above.
    To others who've asked, yes if I had to do it again, I'd still get the mods bit by bit. Cams, then airbox (or vise versa ) then exhaust etc... At the end of the day, what you really get out of this is the journey, the added performance is just a side effecet imho Also each individually add power on their own, and of course they work even better combined. At the end of the day, it's NA mods
    This is good to know. On everything I have built in the past (muscle cars) the OEM exhaust systems were so bad that there were no real gains to be had without tackling that first.
    I would really like in increase torque between three and six thousand RPM. Do the 280/272 cams provide any increase in this range?
    Jesse
  • M3KVU
    2 years ago, I went through this same debate on cams. I reached out to several of the well known members on the forum to gather advice. At the end of the day I was still torn, but decided to pull the trigger with 288/280. This was one mod in a very long list, that was apart of my “dream build” to which I was sparing to expense. See my signature for details.
    Long story short, I collected a lot of dyno data along the way. As an engineer, half the fun was analyzing the metrics. Lang built my head, and installed 280/288 Schrick cams and DLC followers with Paul doing my tune. Being in California, and wanting to stay on easy to access fuel, I was limited to 91 octane. Only concerns I have with the tune is that occasionally I still get the “CSL hesitation” on full throttle, low RPM, sometime.
    I’ll start a separate thread to share all of this info. It will be another good data point for anybody else planning to go down this path.
  • M3KVU
    On cars with csl software (factory or otherwise) if the wind is blowing due East at 22.634 mph and the Earth, moon, and Titan are aligned with each other, then you may very briefly experience slight hesitation when going suddenly WOT from ~3k RPM.
    Lol.
  • duracellttu
    I'm running the Kassel MAP sensor, and still get it rarely.
    Finally, somebody tracked down the root cause! LOL
  • Cubieman
  • BMWahba
    Lol!!!
  • terra
  • ATB88
  • duracellttu
    Originally posted by Dave View Post
    Reliability/follower issues aside, I feel like we're still missing a lot of data on these things. And hell, this thread has proven that even some of the data we thought we had (is what the OE CSL cams are) isn't necessarily widespread public knowledge either. I would like to figure out a way that we could test and answer, from a tuner, on the same car, if the age-old assumption of "288/280 shift the power curve to the right" (so, like Obioban says, 280/272 are better down low) is actually true. We accepted this for years, and thus 288 were less common.
    Then x Spades x and Nick did their cars with 288. And Nick's car with 288/280 dynoed really really high, even in the middle of the curve, because he had Chris on hand in person to sit there and tweak things.
    I think that led to a bit more acceptance of 288s, but it's still one data point, and he had special access to a tuner in person that many of us don't.
    Ultimately, I think we'd all be just fine if we got 280s and called it a day... even if we got a bit more out of 288s, chances are most of us wouldn't know it, or that some of the perceived difference could be a placebo.
    But... I like that we're curious. And I wonder how we can stay curious and try to get more answers.
    So I'm wondering... I have a set of 288s sitting in my garage, I have a stimulus check that I haven't cashed yet, and I have some free time. (Not that swapping camshafts is even that difficult a job once you've done it... but it still requires the ability to set a couple days aside.) I'm wondering if anyone else is also in the same boat, and I wonder if maybe we could band together a group of us to run some tests where we work with both of them with the same tuner, so that that tuner can play with them side-by-side with all other variables controlled. That would serve the dual purpose of getting us all more data and also giving that tuner a ton more experience and authority on the differences.
    Is there a way we could do sort of a controlled experiment here? Say maybe I go out and buy a set of 280 CATs to compare to my 288 CATs, someone else with 280 Schrick buys a set of 288 Shricks to compare, we all work together with Paul and Hassan, and everyone learns a lot? Is that worth our time at this point?
  • x Spades x
    Sooooo what I get from this is.... I'm one of the founding fathers of 288/280 cams. Got it!!!
    I take PayPal gift hugs... :-).
