Hi. I’m looking for a decent affordable scanner that can perform Vanos test. Thx.
Scanner recommendation
I use INPA, BMW Scanner 1.4, and OBD fusion on my phone. All 3 use different interface cables/dongles.
I use these 2 resources for software
This thread describes how I install and configure BMW Standard Tools, the suite of BMW software that includes INPA, NCS Expert, WinKFP, Tool32. I have my own custom way of doing this that is the shortest and simplest steps I could figure out. This set up is for E46 only. What is included...
This thread is intended to contain all information and links for BMW Scanner 1.4. Background BMW Scanner 1.4 runs on Windows, and provides the ability to read/clear trouble codes, view live data, code settings, and test functionionality on most control modules found on BMW models produced from...
you will need to get windows based computer to use INPA (BMW Standard Tools) and BMW Scanner 1.4.
check out this thread on how to run the vanos test with Tool32 that comes with BMW Standard Tools
I'm trying to do a vanos test using INPA but it seems like it's missing that and some other functions. I can connect to the car and get error codes and engine data like rpm, temperature, etc. but it doesn't appear to be fully functional. I've tried two different DCAN cables with the same results. I've reinstalled INPA several
2006 325Ci SULEV |ZF 5MT Swap | Koni Yellows | H&R | 330i Brakes | Magnaflow Catback | AFE | APEX ARC-8 18x9 |
