Hi all,
On 6/7 I replaced my front pads and rotors using BMW rotors (ZIM-150347120) and BMW Performance Ceramic pads (HAW-HB464Z764).
I've done brakes a million times. The caliper piston compressed easily, I greased the back of the pads and the slide pins, I cleaned the rotors off with brake cleaner, put everything back together and set the pads.
Once I started regularly driving I had a high-pitched squeal under braking. It's worst at low speeds, slowly coming to a stop.
I pulled my slide pins out and scrubbed them off with brake cleaner and re-greased them thinking I was maybe a little sloppy on the first go. It worked for a few braking cycles then the squeal came back. I've probably driven ~300 miles since then and it's consistent.
I've had ceramic pads before but on my old Z4, and they were Akebonos (AKE-EUR781) not BMW Performance and they didn't squeak like this.
Is this my life now with these pads? I don't necessarily mind it but I want to be sure I didn't f' it up.
Thank you in advance
Searched for a solution but couldn't find anything so new thread.
