Fuel injector to cylinder fitting
    I am trying to fit some replacement OEM injectors to the car. However, the O-ring that seals to the head doesn't seem to fit in the port on the cylinder head.
    I've lubricated the lower O-rings prior to the first trial fitting but no joy.
    I tried using a pick to ease it in, again no good.
    The original injectors that i removed fit fine. They have been refurbed the past and the O-rings appear to be smaller.
    Has anyone had this fun before?
    I've used a small hose clamp to compress these orings down and then inserted them in. A little annoying of a process but gets the job done
      I should have thought of the Beisan method.
      Thank you.
        I just gave them a wiggle and in they went. Took some pressure, but nothing alarming.
        Did it a couple months ago with new OE O-rings.
