Was going to removed my section 1 to do a little work, but the nuts holding section 1 and 2 are rusted and round. Whats the best/easiest way to remove and replace? Drop section 1 and 2 together and grind the nuts off car? Try heat? Any nugget of advice would be appreciated.
Need advice. Rusted rounded bolts section 1 to 2
Worst cast scenario, a pneumatic hammer will be needed. With that, you can chop the bolts off. It's super loud though. Like 130-140db's kind of loud.This is my Unbuild Journal and why we need an oil thread
i had to drill two of them a bit free before i was able to punch them out with a hammer as they weren't moving at all. maybe that won't be the case for you.Originally posted by humarahumara View Post
Theoretically , If I angle grind off the nuts, it should separate. Curious why you had to drill out bolts. Did the rust fuse them in the holes?2003 AW/BLK 6MT - Instagram
I had this exact problem last week. Here’s what you’re gonna want to do, remove the driver rear wheel and remove the section 3 from the section 2 and drop the the exhaust 1 and 2 together. You must remove 2 reinforcement plates and theY brace or whatever they call it. Then use an angle grinder and grind off the bolts. Stick something like a screwdriver where the bolts would be, and smack it with a hammer. No need to drill them out. If you have any questions let me know
