Edit: Extracting valve cover stud from engine head
    Originally posted by BTB View Post
    Sooo have been ignoring this issue but the stud is still stuck in the head, protruding out just a bit. Any recommendations for the safest way to get this out so I can reuse these threads?? No luck with my own attempts using pb blaster and a cheap clamp-style extractor. I would have someone else do the work if easy enough— maybe machine a small square with 1/4” hole taken out, place over stud and weld around edge, then rotate out with a wrench?
    Appreciate the input of those experienced, thanks
    I recently did this repair on a customer car. He had the vanos worked on years ago and it seems the previous mechanic had cross threaded the corner stud (Valve cover/that area wasn't touched since that repair). When I pulled the valve cover to start a valve adjustment the corner stud was sitting ~3mm away from the surface of the head and was seized in place. This prevented that corner from sealing and the car had a huge mess of oil/grime along the side of the engine as it was left like that for a long time. I tried multiple ways to get it out and none worked and it eventually sheared off exactly like yours. The fix which worked great was to use a M7x1.0 Time-Sert kit. I started by masking off everything (very important to take your time here and make sure everything is masked off completely as there will be shavings) followed by using a dremel tool with a grinding bit to make the surface of the broken stud as flat as possible. I was then able to center punch the stud and then drilled the center with a small drill bit. I gradually drilled the hole larger and larger until I removed the remaining stud material. From there I used the Time-Sert kit to repair the hole.
    Link to the repair kit you will need
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    SF Bay Area Vanos, Rod Bearings, Inspection II, etc. Services : Member Feedback
    E46 M3 Track Videos : https://www.youtube.com/c/DanAvon
      As Dan said above, you are going to have to time sert this.
      These front screws break off all the time, I see it quite frequently.
      Drill the stud, extract any remaining material and time sert.
      Email to [email protected]
        +2 on following DanAvon7's advice.
        I've not done it on a head bolt, but have extracted similar studs using a series of increasing sized drill bits. Sometimes if you reverse the drill direction, it will back itself out with the drill bit. Especially if you let the stud cool a bit after heat has been generated - that stud will swell a bit, so keep that in mind. Don't rush it.
        I've not used a Time-Sert kit, but it looks like a great solution.
