Factory Manual Car- Cruise Control/Shift Lights Not Working
    Ok guys I feel like I’m at uncharted waters at this point on what this could because I’ve done the following and everything is checking out so I don’t really know where else to turn because this is not an obvious problem…
    -checked continuity of all clutch switch wires and confirmed there is no short
    -switched the brown clutch switch for a euro 701 green one then drove the car and hit rev limiter and tried to enabled cruise control. Neither function working
    -brand new gear position sensor that failed a while back
    -brand new cluster (I bought this for a different reason, but it also confirms that the shift light issue is not related here because the original cluster had the same problem.
    -INPA test for chain grip function works as intended (off with pedal out and on with the clutch pressed to the floor)
    -confirmed in ecuworx that cruise control and shift lights are enabled in the csl tune file
    -CSL dme on PD31 via bdm
    -Checked fuse 9 and it’s not blown
    -No obvious codes on any of the modules (scanned the whole car because why not?)
    So at this point, I am completely out of ideas on what else is left because I would consider myself extremely knowledgeable on this platform because I even know the wiring to fix this on SMG to manual swap cars and this is an original factory manual car and I cannot figure out what the hell is going on lol.
    If anyone has any ideas, please chime in because I would love to get both of these functions back and I’m certain that it’s tied to one thing hopefully?
    The clutch seemed like it was the most obvious at this point but Inpa kinda says otherwise because chain grip function works just fine which would not be the case if the switch was wrong and I have both of the factory M3 700 and 701 switches. No change with either.
    2003 E46 M3 TiAg/Cinnamon 6MT
    2005 E46 330i ZHP Imola/Sand
    Instagram:@thegenius46m
