Head Install question
    Hey Guys,
    Im installing a head this weekend and want to see what tool you guys use for the head bolts. I have a Snapon digiatl torch wrench and wondering if you guys use those for the torque and degree turns... or do you guys use the gauges? Just wondering what the best solution is?
    Thanks!
    I used a manual gauge with a clip on flexible wire to have a reference point.
      I used the techangle for both torque and degree
      ‘02 TiAg/Impulse Slicktop
        3/8" or 1/2" ?
          I used Victor Reinz Bolts
          Used one of these magnetic angle gauges on my torque wrench 1/2 inch
Name:	90 Degree.jpg
            3/8" or 1/2" ?
            3/8”
              I was going to say - first step is to remove head from your ass...🤣...but I guess that's not what we are talking about.
              I used a 1/2" snap on techangle. Makes life much easier vs an old school angle gauge.
                3/8”
                3/8" rod will twist too much and the torque angle will be wrong. Use 1/2" for this.
                I used a standard torque to set the initial torque spec, then used breaker bar and referenced to a location on the car for the desired torque angle to get there. Simple and it worked.
                  They always told me it ain’t the size of the boat…
                    Thank you everyone, im on it!
                    So i may need to get a 1/2 inch snap on techangle, as my 3/8 may be inaccurate?
                      Im buying a 1/2" TA for rod bolts, it sucks as I already have the 3/8", such an expensive tool to buy for relatively few jobs that really require it.
                        Which one are you getting? Im online now about to purchase a 1/2 TA.
                          1/2" TA, have the 3/8"s already and have used the 1/2" numerous times.
                          I'm sure MAC, Cornwell etc. are all fine as well, just my preference.
                            If you were able to do the head bolts with a 3/8 then you are stronger than me lol, those fuckers are tight…
                              They all were around 105-110 nm when I checked history on the wrench
                              *edit* - nm
