Low RPM Vibration Diagnosis
    Just some background info. Car has 93k miles. Rear subframe reinforced with Vincebar and plates.
    Diff bushing Poly, Subframe solid, ball bearing rtabs, and spherical upper bearings. fairly fresh guibo. Poly motor and trans.
    STOCK and old driveshaft.
    I am driving and in 2 & 3 gear mostly. at around 2000-3500 rpms the drivetrain started shaking. Like a small vibration out of the ordinary that I know of. During idle NO vibration that I notice.
    Is this a symptom of a bad Center Support Bearing? What are signs of a bad driveshaft?
    I am thinking of getting the JXB Center Support Bearing, anyone have any experience?
    Performance propshaft carrier upgrade keeps your driveshaft perfectly aligned, reduces drivetrain slop, and doesn't sag or wear out over time. 2-piece design doesn't require removal of the driveshaft and installs easily without any special tools.
    If it's the CSB it's speed related and not RPM related.
    If you have the same vibration at the same RPM in different gears then it comes from the engine.
    2004 E46 M3 • TiAG / LSB nappa
      That bearing support will just bring you extra noise and harshness.
      it can also be your clutch and flywheel assembly out of balance. If you rev to that rpm range stationary, does it vibrate?
        I will need to check this. Its the shifter where i feel the vibration coming out of. which is direct connect Kinematic connector.. with poly trans mounts. What can be it be form the engine. No CEL.
        I am ok with the NVH. I will check if it vibrates when revving.
          I'd bet on the flywheel / clutch plate if RPM related.
          Engine vibration damper is not probable as the engine would have grenaded itself already I believe, but I don't know enough about that.
