Search in E46 (2001 - 2006) only
Vehicle Discussion
E46 (2001 - 2006)
Mirror pivot wobble
YYZ-M3
Member
Oct 2025
Mirror pivot wobble
10-16-2025, 10:43 AM
Hard to search for but my passenger side mirror is loose at the pivot point. Is it possible to tighten?
Thank you.
ethan
Mar 2020
10-16-2025, 11:09 AM
There are a couple Torx screws in there which hold the mirror to its base plate which you can try tightening. The threads are aluminum so they like to strip. If you need a replacement base plate, I've used these with good results:
BMW M3 & BMW M5 Wing mirror repair bracket
https://mirrorjohn.com/BMW_M3_e46_M5_e39_Wing_Mirror_Repair_Bracket.php
Just gotta get in there and check it out. Sometimes the hook on the plate is bust too.
Edit - here's mirrorjohn's DIY guide:
Mirrorjohn.com
https://mirrorjohn.com/How_To_Fix_a_Wobbly_Loose_Wing_Mirror_e46_m3.php
BMW M3 & M5 Autodim Rear View Mirror Repairs
ethan
10-16-2025, 11:14 AM
Estoril
Mar 2020
10-16-2025, 12:58 PM
Underscoring that you should not over-tighten them.
YYZ-M3
Member
Oct 2025
10-16-2025, 04:36 PM
Thank you! Parallel question - is there a cost effective way to add motors for power folding or is buying new mirrors the right approach?
