Just curious if anyone else has experience using TC Kline’s Koni Dual Adjustable dampers/shocks. The rear droop is such that when the car is off the ground, the rear spring can fall out of position (when the car is on a lift for example). The lower shock bolt does not need to be removed…they can just wiggle out.
In my setup, I have a 2002 with a typical ride height, Kline’s adjustable perch, and 700 lb springs. (Note these are slightly shorter than 600 lb springs by a few mm)
I’m a bit concerned about this situation for track conditions. So I called to ask if this was anything to be concerned about and the person on the phone assured me there would be no issue. That said he didn’t ask very many clarifying questions.
PS: it’s possible for the car to come off the ground very briefly at the track I’m heading to next. It was not an issue with curbs at Carolina Motorsports park, I didn’t have any problems.
