Cold Start Rattle at 2k RPM
    Hi guys,
    2001 BMW M3 6SPD
    recent started noticing that my car has developed a bit of a rattle on cold start and goes away completely after around a minute of driving.
    I will turn the car on, wait maybe a minute or two to get my music/nav going before heading out, then when i do go, at around 2k rpm I will get a metallic rattle sound from I think the engine area. I make sure to go easy on the throttle until the oil gets up to temp but it will still rattle. After around a minute of driving though it will go away and not come back until the car is cold again. This will happen in gear or revving at idle.
    Ive changed out the timing chain tensioner thinking maybe its oil pressure based (and it has been on the car for 140k miles so couldnt hurt to replace) but didnt seem to help. Rod bearings (OEM) and VANOS (BEISAN) have been addressed at 120k miles (car is at 140k now). Its hard to get a good recording of the sound but I’ll try to get some and post it when i can. I attached the best i have so far.
    TIA!
    Hi! Had my M3 for a while, almost 7 years now, 04 6 speed tiag/imola with 145k km, love the car. Last year after doing a routine oil change (always put bmw 10-60 same brand) i noticed immediately after that on cold starts now the front of the engine makes a rattling noise for about 2-3 seconds and then everything is back to
      The link is the case for empty oil in the oil filter issue, and I don't think it's this case which continued to rattle until after 1 minute, and specifically at around 2K rpm. I think this is related to vanos.
        Are you thinking loose pump disk possibly? I would like to think the shop did a good job installing the beisan unit but would there still be a possibility of it making noise?
          For anybody following, not sure what I did but I replaced the timing chain tensioner as well as my oil filter housing gasket and there is no more noise.
            Sorry I didn't see this post.
            I was think the noise related to vanos piston shaft radial bearings -- plays causing rattle. But now with a new chain tensioner which fixed the noise, I don't understand why a bad check-valve tensioner took a minute to get out of limp while there was plenty of high P oil supply.
