Rear Shock Mounts?
    I really like the RE rubber mounts, they seem to offer the advantages of and aftermarket RSM with no downsides. Also, for not a lot of money R.E sells extra bushes so you can rebuild their RSM's when the rubber is shot.
    That said, those Meyle HD mounts would seem to do the same for less, and have the advantage of being exchanged when worn out.
    If my TCK rear's had a stock diameter shaft I would be running the Meyle's.
      Thanks for your feedback. I'll order one of the two once the situation calms down.
        this is what I'm using, no clunks, dirt cheap, and in theory a slight upgrade.
          Spherical or poly? Mine were spherical, maybe a bad batch. The hole for the shaft was too loose (heh) by a tiny amount, which amplified to an insane amount of noise in the car.
          They were rubber and not spherical which may explain it. Looks like they also sell a spherical mounts I was unaware. Checked my receipt these were the ones I bought.
          '02 M3 Oxford Green/Cinnamon 6MT
          '11 M3 ZCP Apline White/Black SMG
            https://www.rogueengineering.com/Rog...air_p_270.html
            Good to know! I regret buying the spherical versions, live and learn. One thing I’ll say is that Ben accepted a return request from me and refunded me, with an attitude lol, but he did it. Their page makes it seem like the spherical mounts are basically NVH free and that is 1000% not the case.
