Good morning everyone, I recently had the yellow cog appear on my dashboard. The Brake and DSC light also popped up. The cog is consistent so I am aware that there is an actual problem. The car still runs and drives, turns on everytime as well. I was planning on manual swapping soon, but I would like to see if I can fix the SMG issue before taking the leap. How should I proceed with this? Thank you in advance.
SMG Cog of Death
Pull codes.2003 | 3.91 | CMP Subframe & RTAB Bushings | SMG (Relocated & Rebuilt) | ESS Gen 3 Supercharger | Redish | Beisan | GC Coilovers & ARCAs | Imola Interior | RE Rasp | RE Diablo | Storm Motorwerks Paddles | Will ZCPM3 Shift Knob | Apex ARC-8 19x9, 19x9.5 | Sony XAV-AX5000 | BAVSOUND | CSL & 255 SMG Upgrades | Tiag | Vert w/Hardtop
Yes, definitely pull the codes first and you will see. All this combination of light is most likely not due to a salmon relay, but to the car not being able to evaluate properly wheel speed, likely because you have a bad wheel speed sensor. I had the same combination of the lights popping up when I put mismatched wheel sizes one time.
A good way to rule out the salmon relay is to listen for the pump priming when you turn the key onLast edited by E46m3zcp; 11-15-2025, 09:39 AM.
