CSL ECU wiring X60003 pin terminal
    Couldnt get depin wire 1 and ended up pulling out the wire with the terminal still stuck. Now I need to make a new terminal and don't know what part to get. Does anyone know what this wire pin terminal is called and where to buy it?
    thanks
    I just need size and name for those terminals on the bottom.
      TE 1355717-1
        thank you!!!
          TE 1355717-1
          I bought them for https://www.digikey.com.
          What tool do you use to crimp these little buggers?
            I use a Hozan P-707, but basically any open barrel crimping tool will do the job just fine.
              thanks again!
