S54 machine specs
    S54 machine specs
    Happy new years! I found a super reputable shop specializing in machine work for over 30 years. I’m wondering safe cuts specs on an 2005 s54 crankshaft, block, cylinder head, and camshafts.
    Also wondering main bearing, and rod bearings sizes I can safely use after machine work. With camshaft work would it need larger valves too?
    Spec are all found here
    If you're not sure of bearing clearances for a rebuild and how to calculate and measure them (with the proper tools, not plastigage), I would highly recommend you have someone do the build for you.
