LuK clutch with Sachs release bearing
    That’s exactly the strategy most of the veteran owners here recommend. Even though LuK often provides the clutch and flywheel to BMW, the community has found that the non-OE branded release bearings included in some LuK kits can feel 'loose' or of different quality compared to the Sachs unit. I’m one of those people; I’ve done three clutch jobs on two of these cars.
    By sourcing the Sachs release bearing separately, you’re essentially ensuring you get the exact high-validation part BMW intended for the M3, rather than a generic kit-filler. As mentioned earlier in the thread, it's also worth cleaning and applying high-quality grease to that bearing race before install to keep it quiet long-term.
    PS: if you have a high mileage car, replace the release fork and guide pin, and ensure the transmission input shaft seal is not leaking.
      Thank you. I completely agree with what you have written but i just don't see how the cars from factory would end up with a Sachs release bearing if LuK are supplying the clutch.
      We are effectively saying that BMW fitted a LuK clutch and Sachs release bearing from the factory. This does seem unlikely.
        I ordered a Sachs clutch kit a while ago, it was 40 bucks more than the LUK and you just get the LUK stuff in a Sachs box. It had the same wobbly bearing. Some cars that I take apart do seem to have a more solid bearing from factory.
          Were you able to tell what make or see any differences in the ones you removed apart from the wobble?
            In the last 7yrs I've installed probably 20+ LuK clutch kits. Originally I was installing them with BMW TOBs, after warrantying (2) BMW TOBs I now use the LuK exclusively with no known issues.
            Email to [email protected]
              In the last 7yrs I've installed probably 20+ LuK clutch kits. Originally I was installing them with BMW TOBs, after warrantying (2) BMW TOBs I know use the LuK exclusively with no known issues.
              Thanks George, Does this mean you had two BMW throw out bearings fail?
                ac427 correct
                  So, the $64,000 question is which grease type of pack the new bearing with?
