Electrical harness/connector guidance needed (mirror switch relocation)
    I finally completed my harness so I can verify what works. For anyone in my shoes, this is what you need.
    What I used:
    PN 61132359992 - 6 pol socket housing (comes with pins)
    PN 61136913635 - universal 6 pin terminal (does NOT come with pins)
    PN 61131393723 - 05075mm-SN pins needed for the above terminal.
    20awg wire (thanks for the info karter16 )
    SN-58B Crimp Tool (thanks for the info karter16 )​
    Here is a pic showing that 61132359992 works with my switch:
    And my completed harness:
    Which I ran through body/door harness access point using Avedis method in his CSL door panel/center console DIY. Ten separate wires are a lot of wires to run underneath that plug, but it ended up being just enough space. The fact that the wires were silicone insulated and made them more flexible probably helped.
    I have been a member of various BMW forums since 2004, and have learned so much from them. I am in constant appreciation of just how knowledgeable the forum members are, and how willing they are to share their expertise, asking nothing in return. As a general rule, if you are taking on a project, you can find a comprehensive
    2006 E46 M3 Interlagos Blue ZCP Slicktop "CS"
