Looking for Pics of Eisenmann 83mm and/or 76mm Installed
    On the fence about getting 83mm or 76mm. Looking for pics from anyone who has one installed to compare the look from behind.
    83mm sounds really aggressive and I also have concerns about fitment with Status Gruppe rear diffuser.
    06’ E46 M3 ZCP | BBS | Recaro | Ohlins | | Swift | Vorshlag | Hotchkis | IND | Status Gruppe | Future Classic | Whiteline | BavSound | AutoSolution | Euro Headers | SuperSprint | Sunbean | CSL | Revshift
    11' E90 M3 ZCP Slicktop | M-Performance | RevShift | Ohlins | SPL | Turner | Hotchkis | Future Classic
    83mm with standard and chinesium csl diffusor. love it!
    2003 AW/BLK 6MT - Instagram
      83MM. You won't regret it.
        I would say match it to the aggression level of the car.
        Looks funny having 83mm tips and stock 255 tires and/or stock diffuser
          You're hitting on my concern.
          Currently running 265/30 on stock ZCPs. I do have an aggressive set of BBS RSIIs which I don't know if I want to put back on or sell. I have the Status Gruppe CF rear diffuser.
          Ideally i want to match it to the stock ZCPs because id never sell those whereas aftermarket wheels are not a priority for me and will come and go.
            Click image for larger version  Name:	IMG_5833.jpg Views:	0 Size:	169.5 KB ID:	346164 Click image for larger version  Name:	IMG_6962.jpg Views:	0 Size:	174.6 KB ID:	346165​ Click image for larger version  Name:	IMG_6963.jpg Views:	0 Size:	107.0 KB ID:	346166
            83mm Race version, VCSL diffuser, and 10j 275's
            If I'm being picky, they were slightly too big.. but 76mm might be slightly too small. 78-80mm would be ideal.
            Still my favorite looking exhaust I've had though.
              Great shots. That's exactly wha I wanted to see. Looks better than I anticpated. What's your full setup?
              I'm running Euro headers, euro sec 1, SuperSprint resonated Y section 2.
                82mm SGT tips
                It's pretty big. I think 76mm is a better choice unless the car is quite agressive
                  Starts to look cartoonishly big at a certain point. Take a look at a modern G80. Even 80mm will bang against the diffuser on a large bump and that is with a beefed up stock exhaust mount.
                    Agreed, but the pics above from jvit27 don't look as bad as I anticapted. As a matter of fact I can barely tell the difference between his setup and Tbonem3's. I suspect in person there's a noticeable difference.
                      I should post a pic of my old RDsport with 90mm tips That was cartoonish
                      In person, no, I don't think you'd be able to see a difference between my 82mm and jvit27's 83mm.
                        I read that wrong. I missed the 82 and thought you said you were running 76mm
                          Honestly, 76mm looks pretty big. Here's the OZ scorza with single wall, straight cut 76mm:
                            [QUOTE=Tbonem3;n346194]Honestly, 76mm looks pretty big. Here's the OZ scorza with single wall, straight cut 76mm:[QUOTE]
                            It does, but now that I can compare both i think 83mm is the way to go to avoid that gap between the diffuser and the tips.
                              My setup has changed so many times. In that pic it was US headers/Sec 1/SG non res X-pipe/Eis Race
                              Currently running full SS V1 stepped/race cats/dual 2.5 resonated into OE muffler with stock pea shooter tips, and I am in the midst of changing everything again!
