E46 M3 diff mesh pattern
    Happy Easter all,
    I just rebuild my diff with 4.1. Can you guys tell me if the pattern looks ok?
    Not too bad but it's better to add a shim on pinion to get the pattern low on the tooth; it's too close to the tooth crown on the drive side now.
      Originally posted by cnscm2614 View Post
      Happy Easter all,
      I'd run it.
        Is a bit deep, that is why you have a straight line towards the root of the teeth on the coast side. Are you using the original shims from the oe setup or are you starting from scratch?
          Is a bit deep, that is why you have a straight line toward the root of the teeth on the coat side.
          pattern is too close to the heel or toe is not a problem.
            I am using original shim pinion shim from OE set up. But I use racing diff carrier shim kit.
              The line you see from the root on the tooth of the coast side is most likely shadow from light. I looked at it the pinion did not make that line.
                I will share some of the different patterns I got when I did mine. Then you can make up your own mind
