Can someone please direct me to where I can purchase individual valve shims? My motor requires many in the 2.28, 2.30, & 2.32 range. Most kits come with 3 or so of each, which would require multiple kits.
Also, don't forget that you can re-use shims. So if you pull a couple of one size, and then need to use that size elsewhere, you can do that. A simple micrometer (I use the digital one from Harbor Freight) is important to properly size every shim you pull and the replacements you put in.
Found then at the dealer same day with shop discount (cheaper than FCP). Thanks for the resources though as some of these will surely come in handy in the future!
I always ordered them from dealer because the one I used to live down the road from was awesome. Someone still got the sizes wrong. They did overnight shipping and they gave me a small discount. If a parts department knows you, maybe you can get in with them
