Curious whether other BlueBus users have encountered greater than normal background/white noise. Other inputs don’t demonstrate the same noise. If you’ve been able to cut it out, how did you do it?
BlueBus “Noise”
There are a bunch of possible noise sources. There is an issue thread on the BlueBus GitHub project page that lists two potential noise sources:- i-bus interference that sounds like clicking; I don't think you can get rid of this
- alternator whine due to a ground loop and/or leaky alternator diodes; you can fix this with a ground loop isolator (see the thread).
- I recently added a ground loop isolator to my BlueBus and it definitely helped eliminate background hum. I recommend you start here. I believe you can even purchase one from t3ddftw.
And if your previous owner did any re-wiring of the car for you... Good luck. ¯\_(ツ)_/¯
