Originally posted by GT_M3
View Post
Once you remove the chain from the sprockets and before you remove the cams, the crank needs to be rotated 30 degrees counter clockwise to bring piston 1 and 6 down a bit. When doing this, hold tension on the chain with your left hand. Once that is done, the chain can be left bunched up in the chain guides. Refer to TIS, Beisan and the headgasket DIY on m3cutters for instructions.
