Overheated, now stumbling/stalling above 3K RPM
    Originally posted by GT_M3 View Post
    https://www.facebook.com/reel/3599987790174508
    Getting around to working on this - having some issues timing up the engine prior to removing the head. Does this even matter? Let me know if you can't see this video
    That is good enough. Crank pin at TDC, cyl1 cam lobes facing each other, and cams as close as you can get them to lining up with the bridge tool. If you wiggle that exhaust cam back and forth, it should move counterclockwise to line up with the pin, not critical though. There is some residual oil in the VANOS unit that sometimes makes it hard to turn the cam even after you release the VANOS valve body. When you pull the VANOS unit and hubs off, it is much easier to rotate the cams.
    Once you remove the chain from the sprockets and before you remove the cams, the crank needs to be rotated 30 degrees counter clockwise to bring piston 1 and 6 down a bit. When doing this, hold tension on the chain with your left hand. Once that is done, the chain can be left bunched up in the chain guides. Refer to TIS, Beisan and the headgasket DIY on m3cutters for instructions.
      Timing is wrong, redo it.
        He is removing the cylinder head.
          Ok, I was wondering if maybe I had bent something, anyway I guess we'll find out. I wiggled the cam pretty hard but didn't want to break it. I'll continue on using the m3cutters post. Thanks!
            Ok how much did I F this up - removing the exhaust camshaft per the m3cutters guide. I had all the nuts off except 3 and 5. Once I get the 3 and 5 off, i notice the camshaft is sticking up near the firewall. The thrust bridge (?) at the front that bridges the two camshafts is still pretty stuck on there and isn't coming up with the rest of the camshafts even though all 4 nuts are off. I was able to pop it off with a non-marring plastic tool. There was just a ton of gunk making it stick down to the head.
            So, everything is loose, but the cam is seemingly stuck. So I tighten 3 and 5 caps back down in the opposite of removal, then repeat that process without the thrust bridge, and everything comes off as expected.
            I was checking the head to see what I could have screwed up and noticed a slight indentation in the metal, I almost didn't catch it at first, but was able to get a better picture of it. The first two pictures are of the same spot, the 3rd is a picture of the same location on the intake cam. What if anything, should I do about this?
              1) So, everything is loose, but the cam is seemingly stuck. So I tighten 3 and 5 caps back down in the opposite of removal, then repeat that process without the thrust bridge, and everything comes off as expected.
              2) I was checking the head to see what I could have screwed up and noticed a slight indentation in the metal, I almost didn't catch it at first, but was able to get a better picture of it. The first two pictures are of the same spot, the 3rd is a picture of the same location on the intake cam. What if anything, should I do about this?​
              1) with all the cam bearing caps + the front bridge were removed, and the EX cam still stuck to the head? The IN cam was pushed up fine? This makes no sense there is nothing to hold the EX cam down against the force of the valve springs on the cam.
              2) I'm not sure the pics showing the marred area of which bearing saddle, next to which cylinder. Is it the bridge or the one next to it?
              I think the bearings of the front bridge are ruined. You should not remove all the bearing cap nuts completely at #3 and #5 at once, but loosen them slowly and evenly to release the cam upward evenly to avoid cock-eye the bearing cap, in this case the bridge. The fact that the back end of the cam was up high while the bridge cap stuck caused the cam to jam on the bridge bearing surface, dent the soft aluminum of the bearing surfaces. Post the good high resolution pics of bearing surfaces of the bridge caps and saddles.
                For the exhaust cam
                • All nuts undone except caps 3 and 5
                • All thrust bridge nuts undone, but thrust bridge still in place (stuck but I didn't realize it)
                • I loosened 3 and 5 caps 1/4 turn at a time in a star pattern. The cam started to move upward as you would expect, but the front portion of the was stuck down, by the stuck bridge.
                Those pictures are of the bridge itself, the camshaft bearing surface nearest the vanos. I'll take more pics tomorrow
                  For the exhaust cam
                  If you put a straight edge across the dent, will the straight edge stay flat? You can ask the machine shop to check this if you take the cylinder head there. If there are any high spots, they will probably just use a file and take them off to make it flat again. As long as it is flat, it should be fine. Don't worry about the slight scoring in the cam journals. These are used cylinder heads and there isn't much that you can do about that.
                    The marred area is on the side near #1 plug which I don't expect, as the lifted up cam cantilevered on the bridge should have lifted the cap up at the marred area instead of pressing down, so the marred area was done by someone. It's not the bearing surface so just make sure nothing around the area is higher than the rest.
                    Check the bridge bearing surfaces: on the saddle look at the side close the vanos; on the cap look at the side close to #1 cylinder. The areas pressed by the cam at an angle and indented.
                      Juuuust barely I think you're probably right, a slight filing would fix it. Once I pull it all the way off I'll see what the machine shop says.
                        Visually look over the cams to make sure they didn't crack. They are hollow and some people say they can easily snap in half.
