Car had been sitting for a while. Battery was dead, so I jumped it and let it idle. Came back outside about 15–20 minutes later to find it steaming and clearly overheated, coolant everywhere.
I did a full cooling system refresh last year, minus the expansion tank — which I found split in two. That's been replaced now. Could the thermostat have stuck closed? I haven't pulled it to inspect yet.
The engine starts ok, but won't pull cleanly past 2,500–3,000 RPM. No codes on scan. No white smoke from the exhaust. Oil looks clean — no milky residue on the cap or dipstick.
What should I be looking at for overheat damage? Spark plugs? Coils? VANOS? Compression test?
