Was thinking of having my injectors serviced by Race German. But before I do that. What direction should I take when it comes these injectors? Is there a OEM+ injectors that I should upgrade to? Also, something that I don’t need to tune and mess around with. Something to install in the morning and drive in the afternoon. Appreciate all your input!
OEM+ fuel injectors ?
You can't go to a higher flow injector without messing with the tune after.Originally posted by Mustafa564 View PostWas thinking of having my injectors serviced by Race German. But before I do that. What direction should I take when it comes these injectors? Is there a OEM+ injectors that I should upgrade to? Also, something that I don’t need to tune and mess around with. Something to install in the morning and drive in the afternoon. Appreciate all your input!
... and unless you're making a bunch more power than stock (FI), not really any gains to be had.
Does anyone have any experience with Race German's injector rebuild service? I bought a set of detent pin tools that they make a long while ago, and was very pleased with them. My brother however, bought an e30 touring on BAT from the owner of Race German who supposedly did a lot of work on it himself, and that car has been a bit of a basket case haha.2006 E46 M3 Interlagos Blue ZCP Slicktop "CS"
this looks horrible!Originally posted by AmandaB View PostI quit buying from Race German when I used their SS VANOS line that came with these cheap banjo bolts - could never get it tightened right, turns out it was inferior metal and yielded and necked!
Will note to not buy from them. Thanks
you sure you want to be running that vanos line? Updated factory line, with the additional mount point, has proven to be pretty faultless...Originally posted by AmandaB View PostI quit buying from Race German when I used their SS VANOS line that came with these cheap banjo bolts - could never get it tightened right, turns out it was inferior metal and yielded and necked!
unless you're using FI, best thing I'm aware of is to send them off for a rebuild and use good fuel going forward.Originally posted by Mustafa564 View PostWas thinking of having my injectors serviced by Race German. But before I do that. What direction should I take when it comes these injectors? Is there a OEM+ injectors that I should upgrade to? Also, something that I don’t need to tune and mess around with. Something to install in the morning and drive in the afternoon. Appreciate all your input!
It's just a simple scaling of a constant? It's tempting to go this route but don't want to create any issues.Originally posted by m3_sancho View PostWent with the grey Audi TT Quattro injectors.Pretty much plug and play from the physical measurements and connectors. However I did have to change the tune.
