Wheel Speed Sensor
    Wheel Speed Sensor
    Are there preferred options other than OEM for wheel speed sensors (i.e. Bosch, ATE, etc.)? The OEM is pretty darn expensive. BMW part # 34521165609. Thanks.
    Well ATE is OE according to FCP and price is not much less than Genuine. Rock Auto has much less expensive options you could try.
      What are the indications that point to bad wheel speed sensor. Been down this path before and maybe can help you NOT do the same.
      Mike
      02 M3 Titanium Silver / Black
      11 Tundra SuperWhite / Black
        The front left caliper started pulsating while driving without my foot even on the brake pedal. I ran my scanner and came up with failed wheel speed sensor. And if I disable the DSC the problem goes away. I have not jacked up the car yet to confirm any issues with the sensor or ring but my suspicions are leading me to the sensor. Was your problem similar? Thanks.
          No pulsation but had bunch of lights on in dash. Car was in limp mode. Also got “bad wheel speed sensor” as the code.
          Turns out it was the connector coming from inside the car to the rear wheel. It was corroded and falling apart.
          Worth a look before you start replacing things. These cars are old.
          Let me know what you find and good luck with repair.
          Mike
            lots of gunk on mine cleaned problem solved but if not ATE
              I had one die on my daughter's E46, I just bought one from Rockauto for under $20, and it's been fine for the last two years now.
