What does your E46 M3 weigh? Let’s get some real-world numbers
    Finally got my M3 on a certified CAT Scale today, so I figured I’d start a thread for everyone to share their actual E46 M3 weights. My 2006 E46 M3 ZCP
    • 6-speed manual
    • VF570 supercharged
    • StopTech BBK
    • Volk TE37SL wheels
    • KW V2 coilovers
    • Recaro Sportster CS seats
    • Driver + passenger: ~275 lb combined
    • ~3/4 tank of fuel
    CAT Scale Results
    • Front/steer axle: 1,900 lb
    • Rear/drive axle: 1,780 lb
    • Total with driver/passenger: 3,680 lb
    • Estimated vehicle weight without occupants: ~3,405 lb
    • Weight distribution: 51.6% front / 48.4% rear
    I was a little surprised by the total weight, especially considering the car has added weight from the supercharger/cooling setup and BBK.
    It would be interesting to see how much weight varies between ZCP vs. non-ZCP, coupe vs. convertible, SMG vs. manual, and different wheels, brakes, seats, etc.
    If you’ve weighed your E46 on a scale, post your setup + actual scale weight below.
    As much as yo mama
      As much as yo mama
      Hilarious
        ZCP slicktop, smg, with no other options. Will be super happy if I am in the 3200’s after some of the weight reduction stuff I’ve done. I guess i’ll find out soon enough.
          Slicktop, manual, zero options: 3335 pounds (probably 10 pounds less with the Apex wheels on there now).
          Edit: actually probably 30-35 pounds less as I forgot about the light weight battery.
            3050-3100 lbs
            Instagram: @logicalconclusion
              Altaran is under 2600 lbs.
              I've been wanting to weigh mine. I have a lot of carbon and aluminum on the car, but I also have a supercharger/intercooler, rollcage, subwoofer, sunroof, etc.
              2004 Dinan S3-R M3
              2023 X3M Competition
                According to corner balance this week mine weighs in at 3251 lbs with half a tank of gas. It’s a slicktop, manual, basically stripper spec with x2 cobra nogaros, Brembo GT 4-pot (front), SGT fiberglass csl trunk and 18”x9.5 Apex EC7s.
                Edit: corner balance deets below
                  ^ music to my ears.
                    My experience is that "Stock" E46 M3s generally weight around 3450 swinging a little less or more depending on fuel level
                    3449#
                    3443#
                    3434#
                    3487#
                    And for fun:
                    S85 swapped touring, I believe it was at over 1/2 tank, 3602#
                    S54 swapped touring, 3631#
                    6spd ZHP, 3317#
                    Email to [email protected]
                      3240 with half tank
                      Instagram: @s54.m3
