BBS CH-R fitment
    BBS CH-R fitment
    Looking to buy a used set of BBS CH-R’s
    19x9 ET20
    19x10.5 ET25
    Would I have any issues running these specs? Probably would do new PS4S in 235/35/19 and 265/30/19. Any issues here? Do I need to run spacers or anything?
    The fronts will sit like you are running a 39mm spacer on the factory 19" wheels, and the rears will sit like you are running 15mm spacers on the factory 19's. I don't have any direct experience on clearance, but that CHR barrel will be 10mm closer to the shocks.
      39mm spacer equivalent on the front is bad haha
        BBS CH-R fitment guide: do not install these heavy as sin wheels.
        Instagram: @logicalconclusion
          You're not wrong. Really trying to find a set of OE ZCP wheels but it's been hard.
            yeah a little bit haha
              19x9 et 20 would be really aggressive, but people have done it.
              If you don't mind running 3 degrees of camber then they will work.
              The back is pretty aggressive as well, definitely stay with a 265 in the rear.
              2004 Dinan S3-R M3
              2023 X3M Competition
                Those CH-Rs are E9XM fitment. I would not want those on an E46. And a 265 is already stretched on a 10" wheel.
                  these popped up for sale local to me. I think the front will work fine, you'll maybe want a small spacer. Rear is a bit aggressive but I'll leave it to others to chime in.
                  Looking to trade for or purchase a nice set of Style 270’s. Wheels up for trade are a staggered set of BBS CH-R’s that have been freshly powder coated with no defects, wrapped in an almost new set...
                    Technically 255 is within spec for a 10" wheel. 265 is fine.
                      255 and 265 drive like shit on a 10" wheel. The sidewall is so stretched it isn't usable. It would have to be a 265 that runs wide like a 275ish.
                        I have that spec wheel set on my car. I’ll take a picture later.
                        Just some old shitty cars.
