While cruising with some friends, I've been notified that my car has been blowing blue-ish exhaust smoke when downshifting and hard accelerations. Especially if I'm coasting for a bit before I downshift, i.e. coast in 4th, then blip downshift to 3rd for acceleration. Recently did a cold compression test and all cylinders came out 160-170 PSI, the car feels powerful and pulls hard. I've also been burning about 1L of oil every 2500-3000KM. The symptoms seem to lead to bad valve seals/guides based on my research, as during engine vacuum (coasting), oil gets sucked past the valves and into the cylinders, which is burned off when I "blip" downshift.
Is this a known issue on S54s?
Seeking advice.. Is this something I should address immediately? Was actually planning to do my VANOS overhaul but since this came up it might be good to do it all, with head gasket too perhaps.
