What do you all use and recommend to measure camber? Looking for a good value, say less than $300 U.S.
Camber Gauges
Camber Gauges
Last edited by oceansize; 06-23-2020, 05:39 PM.2003 | 3.91 | CMP Subframe & RTAB Bushings | SMG (Relocated & Rebuilt) | ESS Gen 3 Supercharger | Redish | Beisan | GC Coilovers & ARCAs | Imola Interior | RE Rasp | RE Diablo | Storm Motorwerks Paddles | Will ZCPM3 Shift Knob | Apex ARC-8 19x9, 19x9.5 | Sony XAV-AX5000 | BAVSOUND | CSL & 255 SMG Upgrades | Tiag | Vert w/Hardtop
2005 | Slick top | Manual | Mystic | Stripper | ZCP BrakesTags: None
I've been tinkering with a friend doing my alignments and he uses one of these small square digital level gauges with a magnetic base. Just stick it on your rotor (which is parallel to the hub) and we've found that it's pretty dead-on accurate to an actual camber gauge.
I second that suggestion. I ended up getting a very similar one:Originally posted by timmo View PostI've been tinkering with a friend doing my alignments and he uses one of these small square digital level gauges with a magnetic base. Just stick it on your rotor (which is parallel to the hub) and we've found that it's pretty dead-on accurate to an actual camber gauge.
It's magnetic, so when ECS had a sale on this:
https://www.ecstuning.com/b-schwaben.../010891sch01a/
I picked it up. Makes measuring camber and caster a breeze.
Instead of that fancy Schwaben tool, you can get creative with boxed steel from your hardware store. Take about a 19-20" section (measure your wheel), use some bungee cords to hold it in place (strap it to the wheel vertically), attach the level. Done.Build thread: Topaz Blue to Shark Blue
Yeah, those are super nice too because you don't have to do any math to figure out caster. I have a love hate with math.Originally posted by Obioban View PostBuild thread: Topaz Blue to Shark Blue
I have the digital version and it works well.Originally posted by Obioban View Post
http://www.longacreracing.com/produc...Level%e2%84%a2
