Originally posted by Irhase46m3
View Post
FYI: Troubleshooting SMG Relocation Problems
please do! Everyone seems to always route behind valve cover, you are the first i've heard of doing something different.Originally posted by Irhase46m3 View Post
I have it routed over the valve cover, fuel rail, airbox, and the lines drops behind the air elbow and use a heat shielding sleeve, I can send you a photo if you like.
Sure thing, when i step out of the office, I've tried it both ways but with the increasing summer temperatures its impossible for me to keep it behind the block without the fluid overheating, almost burned my pump motor because of it. I am unsure if the burkhart oil would fix this as in their online documentation it says their oil also operates at 140f max, i was getting temperatures of 147f while i was logging the pump.Originally posted by eacmen View Post
Burkhart used to say not to use their fluid for relocation, they have seemed to remove that statement from their website.Originally posted by Irhase46m3 View Post
Yes, everything in my engine bay is using heat protective sleeves from DEI or Mishimoto and their heat protective tapes. Still, the hydraulic fluid would breakdown. I am now pondering moving the pump back into its original location and create a metal heat shield for as its in proximity to the engine. My biggest fuss with the relocation kit is the amount of air that gets in the system and the effort that it takes to bleed it out. What should be a few hours of bleeding is now turned into a weekend project (under my current set of variables)Originally posted by MacCube View PostThere are insulating covers, as those designed for protecting spark plug wires on hot rods, and insulating wraps that could help protect the hydraulic lines. That is something that I have been considering when I get around to relocating my cars pump.
Some have ducted a cold air intake with DC fan onto the pump in its original location with success.Originally posted by Irhase46m3 View Post
As I've considered this I think I'm settling on just changing the fluid every 2 years like brake fluid. It's not like it's 9 liters of fluid or anything. For the gray matter involved, just change it more often. No need to re-engineer another problem and another solution to go along with it, in some vicious cycle as if I have nothing better to do.
$.02
maw
EDIT... I see one mistake that BMW made here, and it wasn't the location of the pump. It was the fluid specification, notably that it didn't need to be changed. Change it often, and you've solved that problem as far as I can tell. MB made that same problem with this same Pentosin, and the same solution applies flawlessly.Last edited by maw1124; 08-16-2023, 04:04 PM.
There is a brake line that runs across the firewall directly behind the engine that has no heat protection, I would have guessed that engine heat would not have been a big problem for the pumps hydraulic lines.Originally posted by Irhase46m3 View Post
The original layout design for the hydraulic lines can do nothing but trap air in the system. The two high points are where the lines connect to the actuator/ slave cylinder and the connection to the pump. It’s surprisingly that the system bleeds as well as it does. This is why I was considering running the hydraulic lines directly to the actuators along the top side of the transmission and then into the drug bin so that the pump becomes the highest point in the system. I know that doing this would be a nightmare, as the transmission would need to be tipped down to gain access, but it should eliminate any problems with trapped air in the system. Theoretically at least.
I relocated my SMG pump to the drug bin 4 or 5 years ago, Has been running well except for the occasional buzz sound. I recently started getting a sound coming from my extended hydraulic line- sounds exactly like a power steering pump when the lines are running dry.
First thought was air entering the system. I traced the extended hydraulic lines back to under the intake manifold and does look like the lines are leaking fluid. Has anyone dealt with something like this? Where are folks getting their hydraulic lines?
Yes, I had lines made locally from a shop specializing in hydraulic lines in Florida. My recommendation is to remove the line or lines that are bad and take them to a local shop that specializes in hydraulic hoses and see if they can make them for you.Originally posted by humarahumara View PostI relocated my SMG pump to the drug bin 4 or 5 years ago, Has been running well except for the occasional buzz sound. I recently started getting a sound coming from my extended hydraulic line- sounds exactly like a power steering pump when the lines are running dry.
Quick update on my side after 4 years now.
SMG unit is still placed horizontally, like OE, in my "bin" on passenger side. Still using clothes and cardboard (I really need to tackle this ...)
Not a SINGLE issue or noise or buzzing sound since.
Here is another update : From my comment "To add some inputs, 2 friends of mine did the mod at the same period (I even helped to complete one) and none of them are experiencing bleeding issue. However, one of them does hear the "First gear" sound like me".
- All 3 of us use/d the Burkhart bracket.
- Both of them ended up having the "1st gear buzzing sound"
- One of them did eventually end up in the same situation as I did : Thrown into neutral, on the side of the road. Moved the pump horizontally, bled, problem solved. Sadly he tried to adapt later on, which would continuously fail because of gear selector .... He ended up manual swapping his car.
To this day, I'm still convinced it's a bad idea to use the pump vertically as you recycle the same air trapped in your system again & again. I'm not a hydraulic expert but is this any good for the pump itself ????
To answer your question mines horizontal like factory and never had an issue.Originally posted by YulCmr View PostQuick update on my side after 4 years now.
