I'm assuming your SMG system was in good health at the time of relocation. Relocating your pump won't fix any existing problems you may have. If your pump is dropping out of gear before relocation there is a good chance it will after relocation. If you also did a pump rebuild the potential number of places where an issue can arise increases. Mainly because you didn't reassemble the pump correctly, your new seals/o-rings have failed/slipped, you over/under tightened the bolts holding the pump together introducing gear bind (5nm), or one of your new sensors isn't working (my new oil pressure sensor was defective out of the box, read -1 pressure in INPA).
Symptoms of air in the system (after bleeding):
You will likely have a buzzing noise (loud to really loud) emanating from the engine bay. This is air passing through the hydraulic lines. The buzzing in my case was even present during the clutch slave cylinder bleed process (oddly enough not during the actuator bleed). You can grab the yellow hydraulic line and feel the vibrations easily (you won't have to wonder if these are the vibrations I'm referencing here should this occur to you as they are very apparent).
FYI: There should be pump motor and mechanical noises during the bleed process otherwise the process should be fairly quiet, i.e no buzzing, whistling, or excessive vibrations in the lines.
Removing the air:
If the pump's accumulator is vertical then orientate the pump so that the accumulator is horizontal with the pump's red snap ring (where the CSL reservoir connects) pointing upwards. Disconnect the reservoir hose from the pump. When I disconnected the hose I saw three large air bubbles exit from the pump within a few seconds. At that point I had the bled the system approximately 10 times. Reconnect the CSL hose and bleed again. After successfully bleeding you can orientate the accumulator back to the vertical position.
Another method should air be trapped elsewhere in the system is to jack the rear end of the car up as high as you can (secure the front wheels so you don't roll) to allow any air to move out of the location where it is trapped. Perform a bleed while the rear of the car is elevated.
Lastly crack the line at the clutch slave cylinder to see if any air exits. You don't have to disconnect, just crack until fluid begins to seep freely.
Car ran great but then the buzzing noise and vibration in the lines returned:
Air is entering when the system is pressurizing and eventually the car will drop out of gear.
1. Check your hydraulic line connections
2. Make sure your CSL reservoir hose is seated correctly within the pump. There is a click or snap when fully seated.
3. Your o-rings inside the black plastic housing just below the red snap ring (collet) have possibly failed.
In my case air was entering where the CSL hose connects but it was fully seated. There are two o-rings just below the red snap ring (called a collet) inside the housing on the pump. You can't readily see these but if you take a flashlight and peer down the hole one is green and the other brown/black. The o-rings were not properly sealing, I guess due to age/use, and when pressurizing air was being sucked in and once pressure was built there was a very slight weeping around the red snap ring. Fortunately I had another plastic housing piece with the collet and o-rings so I replaced the one on the pump with this and my problem was resolved. I'm going to see if I can find the o-rings that reside inside the housing so that they can be replaced. You might ask why did your o-rings go bad during the relocation? I broke my original pump's black plastic housing (that contains the collet and o-rings) on disassembly thus I was using an unknown piece from a second pump I bought. Way it goes sometimes.
My pump pressure is rising and falling way too rapidly:
Air is in your system (see above fixes) or your clutch slave cylinder has gone bad. You can see my pump pressure rising and falling in this video. You might ask why did your clutch slave cylinder fail? My guess is that air in the lines caused a problem or just a coincidence. Crap happens.
My pump motor isn't working but it was prior to relocation:
Check your extended SMG wiring harness continuity. I received a defective wiring harness but fortunately I was able to fix myself. In my case the ground wire wasn't seated in the harness housing properly.
Other notes:
The Schwaben and Foxwell tools are good but I found INPA (with the full suite of SMG utilities) to be infinitely more useful as you can watch hydraulic pressure and temperature live (plus many other SMG and gearbox related items). INPA is very quick and easy to navigate as well. DIS is good but isn't required if you have the full suite of SMG utilities in INPA. INPA can do the accumulator test with the full suite. If you can't find a version of INPA with the full suite then get DIS mainly for the accumulator test but Schwaben offers this test as well.
Removing the air:
Other notes:
