Electric Fan Swap Options
    Bumping this...
    I have a SPAL fan installed in the owm shroud. Id like to remove the clutch fan and splice into the AUX fan controller to rum the E-fan (Essentially having "two" aux fans). I see people deleting the aux fan and running the E-fan on the aux controller and wondering why someone would do that vs just have both?
      Bumping this...
      You can run both, it actually makes sense if you still run AC. It's the DME that turns on the aux fan. Just make sure you use an extra relais and fuse to operate the SPAL fan so you don't overload the cables.
