hi guys,
installed a used engine in my friends M3 and car started ok no issues while on jack stands and we left it to idle for maybe 5 mins. SMG cog light was on but we didnt think much of it... (we reused old smg box, pump etc as was working fine)
anyways turned the car off to add some more PS fluid and then car didnt want to turn back on.. cog is still on, gear stays in "N", there is no crank, but all lights are on as they should be.
used my diagnostic tool and came back with
1) SMG; actuation, clutch, dynamic
2) SMG; selection angle cannot be engaged
i reset the codes and number 1 code stayed on.
i had a look underneath at the slave cyl, pulled it off and it looks ok (dunno what im actually looking for...) and plug was all plugged in fine.
then i redid the codes and came back with
1) actuation clutch dynamic
2) something about PCLD sensor...
anyways cleared these and still number 1 stayed on...
SO... im after ideas what it could be? we are going to try and change Salmon relay, and also try another working slave cylinder....
i can hear the pump price when i open the car door so guessing pump is ok..
