Originally posted by digger
Review: SuperSprint Twin tube (2x 2.5") Section 2
Chiming in on this as I'm looking to get into the SS GB for the 63.5mm system--great thread. From what I read it seems that the 63.5mm section 2 is only really necessary if you are running high HP and other mods like cams, CSL intake, etc.?
My car is totally stock and I'm not chasing high HP, I just need to replace my stock manifolds (bad cats) and pass emissions. For an otherwise stock setup, if I run the 63.5mm manifolds (044001) and 63.5mm catted section 1 (044002), and stock section 2 and rear muffler, is that going to work just fine? Of course, I'd like the full system but cost is a factor. Seems the cats will bolt right up to the Sec2.
Any thoughts are welcome!
The stock sect 2 is a great piece, and it will never be a problem running one, even on a FBO car. Remember, the SS 2.5" is exactly the same as the stock piece, just 3.5mm or 1/8" large diameter.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Originally posted by Tbonem3 View PostThe stock sect 2 is a great piece, and it will never be a problem running one, even on a FBO car. Remember, the SS 2.5" is exactly the same as the stock piece, just 3.5mm or 1/8" large diameter.
No. I have most bolt on mods, no cams, and I felt a little more grunt. I think Hassan demonstrated an 8whp delta but that was with 280 cams iirc.
The aftermarket sect 2s that lose midrange power are the Y pipe aka "Xpipe" style with no crossover.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Originally posted by PSUEng View PostChiming in on this as I'm looking to get into the SS GB for the 63.5mm system--great thread. From what I read it seems that the 63.5mm section 2 is only really necessary if you are running high HP and other mods like cams, CSL intake, etc.?
Originally posted by Cronenberged View PostBump to an old thread. What was the weight of these?
SSV1 header - 15lbs
SS Sec1 Non Catted - 12.5lbs
SS Sec2 Dual Res - 20lbsLast edited by CrisSilberGrau; 12-04-2024, 06:53 PM.2006 Silber Grau Metalizat ZCP 6 MT
M-texture (F2AT) - Turner CSL V2/CatCams 280 272/SSv1/SS Sec1/Sec2 dual res/SCZA TI (raw) - FatCat stage 3 ult 400f/784r - Vorshlag - EC7r 18x9.5 ET35/CRS 275/35/18 - RacingBrake BBK/MileEnd CSL bumper/Vorsteiner Trunk/Cobra Nogaro Circuit Mtexture/GC RCA/YURKan Cages/Hotchkiss/Vibra-technics/
607 likes, 9 comments - supersprint_official on December 8, 2024: "Supersprint just dropped their latest mid-section exhaust for the legendary BMW E46 M3 with the S54 3.2L engine! 🏁 🔥 Key Features: ✅ Oversized twin-pipe (63.5mm) lightweight stainless steel build for max flow! ✅ Perfect pair with Supersprint Race Headers, high-flow 100 cpsi cats, and the iconic Lightweight Race Muffler. ✅ Designed for power — tuned engines hitting 390+ HP! Not tuning that hard? No problem — we’ve got a 76mm single-pipe option for stock or lightly modded setups. 🔧 Fully modular & bolt-on, so you can mix and match Supersprint components to create YOUR ultimate exhaust setup. 👉 Available in straight-pipe or resonated versions. Which one are you picking? 👇 ————————————- A special thanks to @indstyle for the amazing video!🔥".2002 BMW E46 M3 Coupe
2005 Porsche 911 (997.1) Carrera S
Originally posted by R60BBA View Post
