Will post-LCI 330ci LED tail lights work with my pre-LCI 02 M3?
    As the title says... Are newer LED tail lights from an 04 330i coupe compatible (plug & play) with my older 2002 M3 coupe? Thanks!
    Yup. Any outer tail lights from a coupe will fit. Sedan and convertible won't. The inner tail lights are different from the sedan, but the same between coupe and convertible.
    You'll also need the adapter harness (61120153650) and you will need to code your LCM in order to get rid of the bulb out errors on your dash.
      Worth noting that depending on your build date you may have to swap or mod your LSZ/LCM. See here: https://www.e46fanatics.com/threads/...lights.745594/
        How do I code the LCM? I have 0 coding experience and don't want to bring to the dealer for a $$$ coding to just remove the lights from my dash
          I haven't tried it yet using this video, but when I do my retrofit I'm gonna use this as reference
            https://nam3forum.com/forums/forum/s...ith-ncs-expert
            The section titled VO / FA Changes contains the steps needed to do so.
