One more observation, when the main INPA screen is loaded the black dot for "igniton on" is on regardless of key postion, even when I pull the key it stays on.
Intermittent no start, no click/crank
That's just an artifact of the cheap USB cables out there. Vast majority don't have proper ignition detection, but it doesn't really matter for much.Originally posted by Cubieman View PostOne more observation, when the main INPA screen is loaded the black dot for "igniton on" is on regardless of key postion, even when I pull the key it stays on.
Bought a Valeo starter, need to get back in there and re-bend my dipstick anyways, not quite right. Also forgot to clean the ICV and replace dipstick o-ring. First issue I've had one this vehicle in over 2 years and its quite possible the starter is fine and the clutch stop was the only issue.2004 Silbergrau Metallic 6MT
Might want to replace the TPS on the actuator while you're there. And possible the intake camshaft o ring.Originally posted by Cubieman View PostBought a Valeo starter, need to get back in there and re-bend my dipstick anyways, not quite right. Also forgot to clean the ICV and replace dipstick o-ring. First issue I've had one this vehicle in over 2 years and its quite possible the starter is fine and the clutch stop was the only issue.
