It was about 95 degrees in VA and I had just driven 8 miles with the last few around 40 MPH. I pulled into a gas station parking lot and was idling for maybe 2-3 minutes before turning off the engine. I hadn't noticed high oil temps at that time. I fired the car back up about 5 minutes after turning it off and immediately noticed the oil temp needle sitting at the dot between 210 and 300. If the gauge is accurate I'd guess 250'ish F. Water temp remained normal according to the gauge.
I pulled onto the highway and the oil temp slowly dropped to sub-210'ish after a minute.
This is the first time I'd seen that. Where would you start?
