Cold Start Gremlin!
  • High.miles.big.smiles
    Have not reset the adaptations, what does this do exactly? I agree, I need to figure out which sensors the car is relying on in open loop that differs from closed loop since I dont have any specific codes. I also agree that it could be a potential vacuum leak, I have yet to find anything but these things can be pesky..
  • Andy2424
    Originally posted by Pnick View Post
    That yellow looks like an image that didn't load. If you put your cursor on it and right click...
Name:	Anmerkung 2020-08-03 200853.jpg
    I tried that, it doesn't work!
  • Pnick
  • Andy2424
    Originally posted by Speed Monkey View Post
    Time for the peanut gallery 😁 to chime in - cars in general (gasoline ones that is...) when they are stone cold, they run in an open loop, meaning without the use of O2 sensors to govern the air-fuel mixture. The ECU relies on a temperature sensor to default to closed or open loop. Old 911s use a sensor in the block, as with the family of VW/Audi/Porsche products that use early Bosch Jetronic CIS systems, which include K, KE, etc. Our modern M’s use the water temp sensor, or this below:
    Take this as information rather than a diagnosis or an instruction/suggestion to spend $50 bucks on a sensor. Like others stated, do some testing to determine your faulty part(s), then proceed to buy. Good luck squashing your gremlin.
    PS, Every bit as important as the sensor is, it is only good enough based on the connector’s or wiring’s condition. On a car that’s now 15 to 20 years old, the connector might have oxidized a bit which degrades the signal, or if the wiring is moving around, this may lead to slightly damaged conductors that lead to an intermittent connection. Moisture, being that this sensor is very near a water/coolant source, that wicks and works its way under the insulative casing will have a corrosive effect and degrade the conductor’s ability to carry a signal.
Name:	Anmerkung 2020-08-03 085948.jpg
    Thanks for the plausible explanation :-) What does yellow mean? Thanks
  • Speed Monkey
    Click image for larger version  Name:	1CDEFC45-87A3-4F3D-A3E3-CEA7112C0F87.jpeg Views:	0 Size:	213.3 KB ID:	47697
    Monday fun-day where I chime in again, from ECS’s site, temp sensors can be had for the cost of an In N Out double-double combo meal Including animal fries w/extra grilled onions. That seems fairly inexpensive. The original image got deleted somehow, so I am just re-posting the same info.
    Let’s talk about cold start some more as I think it might help the discussion. First, some definition of terms: Open Loop engine operation means the engine is running without O2 sensors engaged, hence “open loop”; fueling is predetermined by a set parameter by the ECU. Closed Loop means the engine is warm and the ECU now engages the O2 sensors to govern the AF mixture.
    Cold Start - When the engine is stone cold, the ECU knows this from the temp sensor, because it is cold. When one turns the key, a cold start (open loop) program is used, which separate and not related to warm engine operation (closed loop). This cold start consists of injecting more fuel in the bore, because when it’s cold, the very finely atomized fuel droplets are attracted to the cold cylinder wall where some fuel droplets condense while others remain suspended just long enough to touch-off from the spark plug, leaving sufficient fuel for cold start combustion. Next, more fuel requires more air, which means the ISV opens up resulting in increased idle. Engine timing as part of the cold start is retarded to compensate for the condition of cold start - remember this, as this is key.
    With that background, let’s run through a scenario of insufficient fuel at cold start. Like that stated, very finely atomized fuel will condense on a cold cylinder wall, hence the term “washing of the bore,” which means condensed fuel washes off the thin oil film on the bore, which leads to ring wear that everyone is familiar with. Anyways, insufficient fueling when it’s cold will lead to a hard start because much of that fuel is condensing on the bore wall, and a rich mixture is mandatory.
    Next for this discussion, let’s say the injectors are still providing insufficient fueling for cold start - at some point when the engine is cranked continuously and long enough, enough fuel will be available for cold start but it’s a rough idle. What causes the rough idle, a combo of a lean mixture and retarded engine timing. Next, you’re late to work as usual so it’s damn the torpedoes and full speed ahead. You hit the gas, the mixture is lean, engine timing is advanced on an engine with retarded timing and bingo, the engine stumbles hard, and the car bucks like your girlfriend when... - well, you know.
    Fueling is key to a cold start. Without enough fuel, some of you may like the feeling of your M3 bucking like your girlfriend, but it’s bad for the sled. Tackle your fueling problem, the hard cold starting, stumbling in cold operation and a bucking ride’m cowboy M3 will likely be resolved.
  • Icecream
    What cylinder is misfiring? All of then or one? Check the condition of the plugs first. Before first start of the day, take them out. Are they dry and healthy? Any mysterious coolant loss?
    How old are plugs, coils? Have the injectors been cleaned/replaced? I had a significant misfire when cold when my injector started failing until it warmed up. Then it failed completely.
  • eacmen
    Was this something that just started happening or did it come on gradually and got worse?
    Some first thoughts:
    Check codes.
    Reset Throttle Adaptations.
    Check for vacuum leaks.
    Clean ICV & replace TPS
  • Mspir3d
    Did you reset the adaptations and drive it for a while? Sounds like a vacuum leak to me if you did.
    started a topic Cold Start Gremlin!
    Cold Start Gremlin!
    Chasing a Gremlin with my 2002 s54...
    On cold start the car acts like it is not receiving enough fuel. It will misfire, and when given throttle, it will choke and drop to 250-500 rpms. If you stay in the throttle it will eventually rise.
    The car will do this until it is warmed up. You then must cycle the key on and off once, then the car will idle and drive as well as ever.
    No codes save for misfire code.
    The car runs PERFECT once it is warm, and will stay running well the rest of the day. Just on initial start up until water temp is around 160, it has these issues.
    Vanos has been gone through, Fuel pump is new, no leaks that i can see, unplugging MAF does not seem to help.
    At this point I am trying to track down which sensors could cause this issue, and then be unred during hot operation. Any ideas?
