I’m in the middle of replacing my rear wheel bearings. On the new F@G bearing I noticed some play with the outer half, inner race. It was like this prior to pressing in, so install wasn’t the problem and I used the proper press kit. I took a quick video to show the play. Is this a defective bearing or normal at until the axle and nut are torqued one? TIA for the help!
Rear Wheel Bearing, Inner Race - Normal or Defective?
2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 280/272 Schrick Cams+P54 Followers | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 336/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | VAC Exhaust Hub | WPC Rod BearingsTags: None
I had another set originally and I don’t remember this much play.Originally posted by FBloggs View PostYou should be ok. Like the fronts, they are "split" bearings.
Once the driveshaft is installed, torquing down the axle nut will clamp the bearings halves anyway.
Don’t ask what happened to those. Learned a few lessons the hard way and had they are broken now. These were a second set I received.2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 280/272 Schrick Cams+P54 Followers | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 336/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | VAC Exhaust Hub | WPC Rod Bearings
Looked at your video again. The Porsche front wheel bearings are not split in 2 havles. I see where your play is coming from. Can you squeeze the 2 halves together and test to see if the entire inner race has play or just the half?
You might be OK once everything is back together, as suggested earlier.
Sent from my SM-G960U using Tapatalk
The “inside” inner race has zero play, it’s only the “outside”. Which is what is leading me to believe there wouldn’t be an issue ones the axle is torqued in. Just wanted to see if others recall the same amount of play.Originally posted by M3GA View PostLooked at your video again. The Porsche front wheel bearings are not split in 2 havles. I see where your play is coming from. Can you squeeze the 2 halves together and test to see if the entire inner race has play or just the half?
Sent from my SM-G960U using Tapatalk2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 280/272 Schrick Cams+P54 Followers | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 336/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | VAC Exhaust Hub | WPC Rod Bearings
It does spin smoothly. The “inside” inner race is tight and has drag, and also spins smoothly. Thanks for the input.Originally posted by bigjae46 View PostI know the inner race has some play in it. The whole bearing is not difficult to take apart.
I wouldn’t be concerned unless the bearing doesn’t spin smoothly with a little bit of drag.
The axle, axle nut and hub is what holds the wheel on.
Sent from my iPhone using Tapatalk2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 280/272 Schrick Cams+P54 Followers | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 336/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | VAC Exhaust Hub | WPC Rod Bearings
