Looking into getting aftermarket sway bars. What sway bar setup should I go for? I see a lot of people going for only a front bar and keeping the rear OE... is this the best option? Any reviews or first hand accounts?
Aftermarket Sway Bars
Are you trying to correct a certain behavior or tune in a certain handling characteristic?
Youtube DIYs and more
Nobody can helpfully answer this question because it depends on your spring rates, corner weights, and handling balance desires.
Preface I have noticed that many cars I see are set up in a way that's at least far from optimal, and often worse than stock. Issues include, but are not limited to... -wonky front/rear stagger -insufficient bump or droop travel -ride height in ranges that compromise suspension geometry -alignments that compromise handling
What are your current spring rates? If they're not too high up front and/or progressive, you'll enjoy a stiffer bar up front. I love my hollow hotchkis. My front springs are "only" 325lb.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
I currently have been running Eibach pro kit springs with Tein springs in the rear paired with my Koni yellows. Didn't want to mismatch but the rear height with the Eibachs was too high.
I forget the spring rates for each. Trying to search up now, I believe the eibach is a progressive but relatively low spring rate, and the Tein rear is 532lb?
So looks like a hotchkis front bar would be a good fit ?
Eibachs are only 8% stiffer than stock up front. They also are meant to be paired with the Eibach pro-kit sways iirc. Increasing the stiffness (a medium setting for most bars with 3 holes. Eibach has 2 holes, so go with the inner) of your front ARB would have benefit.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Do you know the dimensions on eibach’s bars?Originally posted by Tbonem3 View PostEibachs are only 8% stiffer than stock up front. They also are meant to be paired with the Eibach pro-kit sways iirc. Increasing the stiffness (a medium setting for most bars with 3 holes. Eibach has 2 holes, so go with the inner) of your front ARB would have benefit.
Only that it's 29mm, not hollow, with 2 selections for adjustment. Front.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
