Well, as some of you may remember I toasted my engine recently. And I opted to do a rebuild instead of buying a new engine. At first I was on a budget simply because of shock. But now a few months later the rebuild is going along nicely and I’m starting to realize that this is my chance to do major work.
I was originally going to go with reusing my OEM rods. Then I started thinking about my build and thought that they were the weakest link in the system. While I do not plan on boosting the car or adding any major power upgrades in the next year or two, I want to try that later on in the future.
I went with CP pistons and it seems like the most popular/best choice is the forged CP rods as well. Anybody have any recommendations or experience in this area?
Here’s a link. https://store.vacmotorsports.com/mob...t-6-p3815.aspx
And if anyone cares or remembers the primal post I made here’s an update on the build process. The block cleaned up nicely to 87.25mm. Achilles Motorsport provided custom extra high valve clearance CP-Carillo pistons at stock CR for LESS than what everyone else charged for off the shelf pistons... those just got sent out for skirt and top coating.
I’ve purchased a new (used) head. Valve seals replaced. Cometic MLS head gasket. ARP head studs. BMW WPC rod bearings. Calico Coated OEM main bearings. OEM main bolts. I’m sure I’m forgetting some little stuff. I’ll have to make a final update when everything is finally put together. Including a price sheet!
