Originally posted by sapote
E46 M3 S54 Vanos pressure tests
Originally posted by Santino View Postbut in my understanding the vanos pump is running constantly, unlike the smg pump witch also used the pressure acumulator
Originally posted by sapote View Postwhat do you mean "upped the pressure"? You adjusted the pressure regulator -- to how high?
It dropped rapidly because there was no reverse from dead ACC.
Also, during driving the pump turn on vs turn off duty cycle is too many, leading to worn pump/motor quicker.
about the price in europe price is better than us sites,
Zbiornik ciśnieniowy - 11367836050 / 11 36 7 836 050 - cena oraz dostępność. Lista modeli BMW / Mini gdzie znajduje się Zbiornik ciśnieniowy
540zl is something about 135usd, but ive got better discount and also possibility to buy without 23%tax , so its like 99 usd
Originally posted by Santino View Posthere is the vid i took before upped the presure one the vanos unit
Not normal. I believe it dropped (as the DME changing the VANOS timing when rpm changing) because there is no accumulator pressure reserve in the old tank with empty N2 gas. Need a new ACC bottle.
Originally posted by Santino View PostHi guys ive just mesured my vanos pressure it was reading 100bar (vanos was rebulid with beisan seals few k earlier)
did up the pressure for s54 specific 115bar, it is reading some presure dips when hiting the gas pedal
is it normal
is it normal i thougt i saw a vid that pressure stays constant when hiting the gas
I was able to run my VANOS test with ISTA+, and the VANOS passes the test. Below are my results
Timing
(Actuals vs Nominal)
Exhaust Advance: 128 vs 128
Exhaust Retard: 79 vs 80
Intake Advance: 70 vs 70
Intake Retard: 130 vs 130
Tolerance in ISTA is +/-5 degrees
Adjustment Speed Exhaust
Advance: 293ms
Retard: 293ms
Adjustment Speed Intake
Advance: 293ms
Retard: 293ms
Limit in ISTA is 500ms
Exhaust
Setpoint 113°
Actual 111°
Leak Exhaust: 2°
Intake
Setpoint 115°
Actual 114°
Leak Intake: 1°
So based on this my VANOS is ok, the adjustment time I think is on the high side, I have seen results of 190-220ms. All this means I have no leaks and timing is right on the money
I think the response time can be influenced by the low pressure, based on my results it could just my regulating valve as everything else is working fine. I also noticed I don't hold pressure after shut off so my accumulator may be bad too.Last edited by maupineda; 09-18-2020, 04:47 AM.
I found this interesting post, is for the S62 engine, but it seems to be the same logic for the S54. So a pressure leak can indeed also come from the solenoid pack.
In my case, I have new seals, and the solenoid body was cleaned thoroughly, I, unfortunately, did not know all this so I don't have a test before my VANOS overhaul.
I have bought an ICOM to run the VANOS test with ISTA+, this will at least confirm if I have leaks or not, if I do, I may have leaky solenoids, based on what I was told by BEISAN is unlikely seals have failed in less than 2k miles, and my car has low miles for the pump to be the problem.
If my VANOS test passes, then it would be the pumpLast edited by maupineda; 09-12-2020, 03:41 PM.
After replace the accumulater.Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.
Finally I got the prussre testing kit, noticed rattle on the reading max 115 bar with flickering. On engine shutoff the pressure reach 30 bar in 4 to 5 sec.
so I change the vanos pressure accumulator.
problem solved.
Originally posted by sapote View PostThis sounds like you have a bad leaky vanos piston seal; could be damaged seal during installation. Or not having enough oil supply from the head: caused by a blockage regulator (the one between the head and vanos).
This is what I was afraid of, that my unit has an issue. Where did you source it from? Raj told me my car has too low miles for the pump to have worn out but, I guess it can happen. Before throwing a new unit on I will change the restrictor valve as I damaged mine trying to disassemble it and noticed the internal cone has a scoring. I am doubting this be the issue but Hey, maybe I have a worn restrictor and being the cheaper part I will start there
