Brake Fluid Light
    Brake Fluid Light
    Hi,
    I'm having problems with my brake fluid light, the reservoir is full and i'm not experiencing any leaks. i was thinking it could maybe be the sensor inside the reservoir is malfunctioning?
    I was thinking about replacing with this part:
    https://www.fcpeuro.com/products/bmw...ir-34326750798
    my question was, is this the correct part? would this solve my problem?
    thanks!
    for reference:
    2005 silver grey convertible
    114,xxx km
    bilstein b12 prokit (eibach springs)
    wheels are hre 540r 245/35/19 275/30/19
    front lip is happybuyitnow (ebay) gloss black plastic
Name:	e46m3convertible aug2020.jpeg
    This should do it: https://www.fcpeuro.com/products/bmw...ap-34336774451
      I replaced the sensor and the brake fluid light is still red. What could it be? Shouldn’t it just turn off by itself?
        Are you talking about the yellow light that’s circular
        If so,
        Have you checked your pad wear
        The light comes on if your pad thickness is below a certain level.
          It looks like ((!)) but red
          all four brake pads are good and fluid is good also.
