Tool Rental Thread!
    Tool Rental Thread!
    Edit 5/22/20:
    This is no longer where tool rentals should be listed. We now have a forum section for this sort of thing:
    https://nam3forum.com/forums/forum/c...ntals-products
    I have a full set of specialized tools for the Beisan Vanos upgrade.
    • OEM Camshaft Alignment Bridge w/1 Pin (83300493749)
    • OEM Flywheel Locking Pin (83300490861)
    • Craftsman 24mm Combo Wrench - just barely thin enough to fit on the cams, most 24mm wrenches are too thick
    • Craftsman 9-47412 Retaining Ring Pliers
    • Beisan S54/S62 Vanos Rattle Tools
    These are basically all the tools needed in addition to basic hand tools to install the full Beisan Vanos upgrade, including the anti-rattle kit.
    2 week long rental with a $200 deposit via PayPal. Renter will receive refund of $160 after all tools are returned in clean, undamaged condition. Buyer pays actual shipping cost via USPS both ways (approx $10-15 each way).
    I can also rent out the tools separately, and charge a reduced rental fee based on what you need.
      Cool
        Anybody have the front wheel bearing removal tool? Like the one in the link below. BMW Part #83-30-0-491-905
        2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 288/280 Schrick Cams+DLC Followers | Lang Head | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 400/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | Turbo Toys V2 Hub | WPC Rod Bearings
          fwiw, front bearings are easy. You'd need tools for rear. Also, Our hubs are an assembly with bearing, not like other BMWs necessarily. You buy the whole FAG assembly.
            Anyone have the front diff bushing removal tool? Kommen BMA1153, HCB a1153, or Baum B333370
              I will try to compile a list of all available specialty tools complete with prices and part #'s for the E46 M3
                This thread is now unstickied. If you have a tool you want to rent out, we now have a dedicated section to
                do so: https://nam3forum.com/forums/forum/c...ntals-products
                  ANyone have front and rear main seal install special tools??
                    Rear main doesn't need a special tool with the updated part number. Comes with a plastic sleeve that is used as the tool.
                      I was hoping to not buy the 115$ "kit" including the seal pre pressed in the housing. I have a rms already and was going to reuse the housing. Are u sure i dont need the tool to press into the housing?
                        Ah not sure about pressing into the housing. I'm assuming you could get it to work without the special tool, but you would need to find a way to drive the seal in perfectly straight.
                        To install onto the crankshaft you definitely don't need a tool. Take a look at this: https://www.newtis.info/tisv2/a/en/e...covers/BB058mu
                          Hey man, how much to rent the Cam alignment bridge with pins? I need it to install cams.
                          Let me know, not sure if I'd need anything else beside the bridge?
                          Current:
                            PM'd on the cost. Not sure if you need any other tools for cam install though, I've done cams before but not on this motor.
                              Thanks, anyone chime in ?
                              Current:
