Looks like my exhaust clamp has cracked. Can this part be replaced?
Exhaust Clamp Cracked
Yes, part no 18111719417.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Just be happy it was the sect 2 slip on side, not the flare end or the sect ends! It'll just slide off and you slide the new on one (similar to our headers).
Agreed. I'd just fix it the next time you drop the exhaust for something or change sect 3s.Originally posted by T.J. View PostMine was like that for years before I put on an aftermarket muffler on. I doubt it will leak if you don’t touch it
Along with replacing the rusted/cracked flange you will also want to replace the exhaust gasket ring on that pipe as it is also cracked. It is part # 18101405737. I would also replace the bolts/nuts as they look pretty rusted too.SF Bay Area Vanos, Rod Bearings, Inspection II, etc. Services : Member Feedback
E46 M3 Track Videos : https://www.youtube.com/c/DanAvon
