    Smoke testing for vacuum leak. Is there a decent low cost tool/DIY setup for this?
    I made one from a pickle jar/soldering iron/sock/baby oil and bike pump later replaced by a airbrush pump I already had. It worked pretty well actually. There is a YouTube on it.
      Can someone link me to a page or video that shows exactly how the S54 VANOS works? I'm trying to understand why the exhaust hub has tabs but the intake side doesn't.
        The exhaust cam and hub tabs drive the oil pump disc in the VANOS unit to generate the oil pressure required to advance and retard the cams.
        Skip to VANOS section: https://bmwtechinfo.bmwgroup.com/tec...%20Vehicle.pdf
        http://uploads.tapatalk-cdn.com/20170709/b427cc1ecdc0899673ce51539b3394e1.jpg http://web.archive.org/web/20180214064458im_/http://uploads.tapatalk-cdn.com/20170709/a40017b090c94ffa891574d94069c3c0.jpg Disclaimer: ( Most of the M3Forum links below do not work anymore ) Please read and completely understand the timing
          https://nam3forum.com/forums/forum/m...os-info-thread
          Thank you! Could BMW have designed the intake cam to be the one with the oil pump disc?
            Probably, they did that on the S62.
              ^ Interesting. Why intake cam on the S62 but exhaust cam on the S54? Are those the shortest ways to run the chains?
              2008 E90 M3 6MT
              2011 E90 328i 6MT
              RWD, slicktop, no iDrive
                Activated Charcoal Canister Cover (PN 51717893604) question - Is there anything behind this heat shield that ties into the canister cover or is it open? If there is a plastic piece coming down that the heat shield is covering, can you help me identify the PN?
                Click image for larger version  Name:	image.png Views:	0 Size:	349.5 KB ID:	286084
                📸 @alpinem3
                  I have an drift day coming up.... There is potential for wheels off, and I want to ensure no airbags pop.
                  Y'all have any quick ways of disabling airbags? I have ncs expert if needed. I don't want to have to physically disconnect anything.
                  Is as easy as just pulling the fuse?
                    Nothing, just remove it. I replaced my charcoal can 2 years ago; black box comes right off.
                      Thanks for the picture. And kudos to you for the proactive maintenance.
                      I want to make sure I’m not misreading your response - did you remove the plastic housing altogether? If so, no issues leaving the charcoal canister assembly exposed to the heat and elements under the car?
                      In was planning to drill the 4 rivets out that connect that lower part of the shield to the plastic housing. Assuming there was something behind it, I was going to cover that with some heat tape and call it a day. The fact that there is nothing behind the heat shield complicates that plan….back to the drawing board.
                      📸 @alpinem3
                        Sorry about that, I should have been more clear with my response. That photo I posted was just for my record of the car when I replaced the canister assembly, taken before I put the black plastic cover and heat shield back in place. I thought your question was just for the purpose of removal to access the canister for repair.
                          Thanks for your response nonetheless. Nice to know what’s behind that cover 😄
                          📸 @alpinem3
                            I swear I had pictures of what was behind that cover when I replaced the DMTL pump a few years back. I can't seem to find it but it looks like you got it...covered
                            2007 GX470
                            build/journal
                            ig: @zzyzx85
                              When installing an aftermarket wheel hub, does the clockspring have to be in center position if not running any wires to the wheel? (no horn, airbag wires staying inside hub w/ two 2hm resistors)
                              The OMP wheel hub I’m installing wont mount with top hole centered (and thus wheel wont be centered) unless i rotate the clockspring left by pushing down on that bottom detent spring to position the two knubs to fit into the centered OMP hub.
                              Wondering if this would cause any issues, and if it’s a critical concern? Not sure what that bottom detent spring being depressed in that position would do? Would the steering feel weird turning it from off center with the clockspring like that?
                              (Pic 1 centered clockspring, pic 2 how i need to position it so the hub+wheel mount centered on the locked steering column spline)​
                              Click image for larger version  Name:	IMG_9566.jpg Views:	0 Size:	120.3 KB ID:	286589 Click image for larger version  Name:	IMG_9565.jpg Views:	0 Size:	129.9 KB ID:	286590
                              2004 CB/Cinnamon 6MT Coupe
                              Youtube
                                I think you will need to recalibrate it to learn its zero position. The SCCM also is used by the DSC, the car will see an unexpected angle versus yaw and wheel speed..
                                also it will spin more to one side on lock to lock conditions so you need to make sure there is enough cable inside the spool. I think it does as the angle is not that much but not sure how much slack there is. Record the position and spin it in both directions to see how much there is lock to lock, be careful as there is no mechanical stop other than the internal wiring. As long as there is enough rotation based on the cars lock to lock turns based on the steering column limit you will be fine.
